AC mod Override possible?
its got one "input" and two "outputs"....
the CURRENT vac. line connects to one side (12v terminal side)
w/ power off the vac. can flow normally w/ 12v applied it switches
to the other "output"
so in my case i want to use it to PULL the freshair/recirc. door SHUT
when im running the A/C in bi-level (dash & floor) mode.
the problem w/ a "seasonal" lock-down (open or closed) is that
you may need fresh air when it rains...and you may need some
temp/mix if the windows fog...
Ricksofla
