about had it with this rag...
nagging hi-frequency vibration for the last 20,000 or so..
been trying to pay off debt so not a lot of jingle left over for "non-essential" (ie, will still get back & forth to work) repairs...
so as I got time...
changed all the u-joints.. AGAIN... no change
changed the carrier bearing... AGAIN.... no change
changed the slip yoke... thought I had it on that one.. until I hit an expansion joint in I-465 and viberated all the way down to Bloomington and back home...
pulled the driveline and sent it out for balancing... another step forward until I hit an expansion joint on I-94...
so FINALLY I pull the driveshaft again, and send it to another driveline shop... this time, he replaces all the companion flanges. So I buy the one for the rear diff as well...
while I have it off I check the pinion bearing...
so a set of pinion & carrier bearings, all the yokes and companion flanges, support bearing, balanced twice and three sets of U-joints and A THOUSAND AND THREE HUNDRED FREEKING DOLLARS later.. I finally have a truck that doesn't put your feet to sleep at 70 mph again..
remember the second sentence when I said I was "trying to pay down some debt?"
I want to say the trouble started in the rear companion flange..
that f'in thing never would hold a u-joint tight...
02Oilburner
SDD Power Hungry
Raleigh, NC
Hmmm. I have a slight vibration at around 70 when towing and I get a clunking when I turn while towing also. Is this what is going on my truck? How much for just the carrier and pinion repair?
for me to do it in my shop?
$1300.
I got about $600 invested in the driveshaft and a lot of my own labor..
Dieselpwrdredneck
Addicted2Diesel
paris, Ohio
my buddy had a bad vibration like that in his '01 we went thru all the drive shaft crap low and behold it was the friggin needle bearings in the wheel bearing assebly
been down that road, too..
I couldn't get one hub to lock in (Warns, on top of that.)
hub and a stub yoke...
not bitching, I knew what I was getting into when I bought this rig, but jeezus.. you don't open the hood without it costing you $100.
I was thinking that, but I just dropped $9,000 on a tractor, so I'm not exactly cash flush...
