7.3 oil leak
fredericks24
morris il.
Hi everyone,
I am new to this site and just wanted to say hello and ask if anyone has had the problem? I have a 2001 f-350 with a 7.3 which I might ad is a assume truck! The problem i am having is that i have a oil leak that is on the bottom of the motor does not look like the pan or rear seal is leaking other people have told me it could be many things such as the hpop, turbo ect.. any ideas ????
Stroked68
This is FORD Country
Eudora, KS
Yea I'd look in the valley on top of the motor. Usually o'rings start leakin. I'd check there first.
Welcome to SSD.com. Hope someone can pinpoint for you where the leak is.
Good Luck, how many miles on the truck.
fredericks24
morris il.
fredericks24
n
I FOUND two oil lines a little lose next to the fuel filter i think they oil lines not sure but i thighten them up, hope it is that simple! The truck has 255000 on it and not a bit of trouble other then door locks and windo0w motor going out several times.
FlorWhitfe
