6 ohs running poorly
Akpaul
Wasilla,Ak.
Three of my 4 6.0s are running bad and popping through the intake, any ideas?
DR.Diesel
marlow ok
you need to get the codes read and find out what hole is missing.i have a o4 engine in my shop that had a popping noise in the intake.did a compression test and didnt have any on one of the holes.pulled the valve cover off and checked the valve train for that cylinder and found the bridges off on the intake.i had a failed lifter.ended up puttying in a used engine.
Akpaul
Wasilla,Ak.
they dont seem to be setting code, no eng. light on but they are all missing. Thinking possibly injectors, have done no trouble shooting yet.
RoyBoy
Diesel Dork
central WI
I had that problem on mine a few years ago, turned out to be a bad exhaust cam lobe.
TacoCat
