4x4 won't engage in cold
Wingdog
Thunder Bay, Ontario
The vacuum hubs are not a maintenance free item. Pull em off, clean and regrease with a light oil. Replace the orings and check the vacuum lines going to the hubs.
A little care and they will work fine.
Tbar
Are they a big issue to remove and clean? What is the best way to test the vac lines? Is it the hubs that engage first or the transfer case?
dmd
Member
Double Oak, TX
If the light comes on and you get 4x4 then vacuum is not the issue, neither
is maint of the hubs.
