Jim up north
Do the front hubs have to be in " lock " mode to engage the 4x4 low range?
Never had this setup on my other 4x4's . When I engage the switch ( new thing again) to 4x4 regular the light comes on , yet when I turn it to 4x4 low the low range light does not come on . Is this still vacumn operated like the F-150's? Should I go into a lower gear for the low range to work? Is it possible this is controlled by a fuse? Violent storm last nite up here would have like 4x4 low to have worked, to drive slowly thru washout(anyway)
Jim
P.S. Took a chance on one of the threads about the egr valve, disconnected it ( althought engine was still cool early morning, punched it to pass someone
no sputter)
Jim
no sputter)
