4x4 low range
jharvey
Shutter Bug
Georgia
Munkey said:
I thought you have to be in neutral and put your foot on the brake too for lo range.
That's correct, stop, foot on brake, tranny in neutral and then flip the switch over to 4 low.
Kleetus
Butler PA
fordtrucknut said:
I believe the auto hubs are run w' vaccuum. This is my first auto system. Red 6.0 had it correct, stop, neutral, switch to low, put in drive and hang on!
As far as I know, the F250 on up does not use vaccuum to engage the hubs. Smaller ones, yeah, but not ours. I could be wrong, but I don't think so honestly...
nascar_fan28
IL
i tried 4low once and i dont think it engaged.. i even backed up to try to get it engaged.. im gonna try again.. i kinda want to see how slow truck goes with it in low 1st with it in 4low, guessing pretty slow
f100cleveland
When In Doubt,THROTTLE ON
Southern Minnesota
I drive a few hundred feet with mine very slow, letting off the throttle every now and then and it finnally will go into low range. I've tried going forward and backing up but that didn't work. Getting it outa low can be fun too.
Crazyhorse
Suisun, CA, USA
I don't know about your 06, but my 03 has vacuum lines rinning into the knuckles...
Kleetus
Butler PA
OKay.. you're gonna make me ready my service manual... dang it...
Maxtor
Redding
My manual says:
1. Come to a complete stop
2. shift transmission into neutral
3. place into 4x4 low
4. shift into drive
5. drive away.
To take out of 4x4 low
2. shift to neutral
3. place into 2wd
4. shift into drive
5. drive away.
Jriltex
