I leave mine locked in for months at a time in winter. It won't hurt anything but your mileage.
False. The bearings have nothing to do with the lockup of the hubs. Bearings spin either way, locked or unlocked. Locking your hubs won't wear anything out any faster....Tony Montana said:Ok everyone thanks for the help Hoss 350 you explained it very well. Now one more question someone told me keep in free position , unless in 4 wd or you will be buying $400 bearings
Probably normal, but hard to say without hearing it. Keep in mind that you are spinning an entire differential, axles, and carriers in teh T-case that you are not used to hearing. You can definitly hear mine when it is engaged...scottsxf said:I typically would also leave mine locked in in wintery conditions. With this new one, 2006 PSD autohubs, electric switch 4x4, it is somewhat noiser when engaged then my previous 1/2 ton trucks. What is normal? I can here the axle spinning as a whirring noise and also a whiring on acceleration and deacceleration. Most of my 1/2 tons were extremely quiet. It is not real loud but noticeable.
Scott
