2011 f30 snow plow pkg
stang13
pgh pa
Hi I am waiting arrival for my first ford truck . I have the snow plow pkg option added to my order and had a question . I know that the pkg consisted of heavier front springs , does anyone on here have this option and if so does the truck sit level or does it still have the rake to it ? I wanted to try and run 33's and I am not sure if they will fit without a leveling kit
Tom
Fine69
Cranberry Twp,PA
I have it on my 09 and the front still sat 2.5-3" lower than the rear. I added a 2.5" leveling kit and it sits nice now. I'm running 325/65/18's, which are the equivalent of a 35x13.5" tire, with no rubbing at all.
stang13
pgh pa
Hi Bob
Thanks for the info are you running the factory rims ? If so what is the width . I am going to have the 20 " wheels . Do you think that 33X 12.50 X 20 will fit with out the leveling kit then ?
I see you live in cranberry I live down rt 19 in wexford
Reverend Jim
usa
Tom,
I have an '09 F250 with the 6.4L, it has the snow plow and FX4 packages. It sits level front to rear, and the stock tires are 275/65-20. These are a true 33" tall by 10.5" wide tire, (measured with a tape-measure). Hope this helps with your decision.
Fine69
Cranberry Twp,PA
Tom,
F250's often sit level because they have a smaller rear block, so comparing to an F350, they usually will appear to sit level.
Fine69
Cranberry Twp,PA
Hi Bob
I run the factory 20" wheels in winter with 325/60/20 Nitto Terra Grappler's, which also are 35" tall and approx. 13" wide. Factory 20's are 8" wide. In Summer I use the tires and wheels listed in my signature. 33's will DEFINITELY fit without a leveling kit, they may even look small.
I live just north of you in Cranberry, actually grew up in Franklin Park, even closer to where you are. Welcome to SDD!
dc.snowball
bear, delaware
stang13...dc.snowball here...i have an '11-350-20"rims-plow prep-& all the goodies. springs are same with or w/o prep.(w/6.7)...6000#fr.axle...skid plate ..alt +few other goodies... stock its about 2.5" front rake... with a fisher plow frame kit.. we pull heavy eq. we put an 1.5" level kitand it leaves@ 1' low in frone ...but with any wt. in the back it works out great. for load dist.
Hey dc, fill out your signature so we all will know what you drive. Go to the QUICK LINKS in the TOP BLUE LINE and click on EDIT SIGNATURE. This will better help us help you. Thanks.
Dave :)
