2002 Powerstroke NO START
dMerre89
OK, so last wednesday my truck started running very rough and wouldn't harldy idle... and eventually wouldn't even start. So I had it towed home, replaced the CPS and fuel pump.. Nuthin, so then I dug into all of the fuses and every one of them are good. No codes came up on the scanner. When I turn the key on, the glow plug relay smokes and gets hot. While cranking, white smoke comes out of the exhaust. I am in the process of taking the valve covers off and checking the harnesses. I have the drivers side off and it looks good except for one break in a wire, but there is still a connection, Ill definately replace that, but I doubt that is the problem. I am workin on getting the other valve cover off, its a pain in the butt... but hopefully there will be something else wrong over there and hopefully thats my problem, but if its not, then I don't know what else to do. Any help would be appreciated. ive been on this for about 30 hours straight trying to get it goin...
dpantazis
#12
under the cheddar curtain
first things first!
find out why the GPR is smoking. if its bad then fix it to eliminate that problem.
rumor is the Stancor relay is cheaper/heavier duty. search for it on the forums.
dennis
roosterdiesel
Earl needs B100
Amarillo,TX
Smoking GPR....not good...find out what's causing that.
White smoke out the tailpipe means you are getting fuel out of the injectors but the GPs are not hot enough to get the fuel ignited, back to the smoking GPR. You could try jumping the GPR, with the key off, take a set of jumper cables and put red clamp on one post of the GPR and the other red clamp on the other post of the GPR for 10-15 seconds then remove and try and start.
Also how old are the batteries?
dMerre89
I have it in a heated/insulated shop now, and the batteries are the original ones. What could I check to see whats causing the GPR to get that hot? Could the relay itself be bad and shorting out? Or could I have a bad set of glow plugs? Thanks for the help guys
Your batteries are at the end of their normal life. I used to change mine every 3 years like clockwork. The glow plugs draw a lot of current and that will drag down your batteries to the point where your starter will not spin the motor fast enough to start.
dMerre89
checked the batteries today and their fine... thinkin about changin the relay. Thanks guys
dMerre89
just put brand new GPR and new set of batteries and nuthin, im takin it somewhere, tired of it
ACERATI50
check the passenger side valve connector also the clips inside the valve cover let me know i am pretty sure it is that ,,, do your batteries die after cranking it for a while???
dMerre89
yep, already pulled those off, but found nothing.. Took it to the stealership yesterday.
Ricksofla
