Question 2 stroke oil in diesel fuel?
skertin3rd
Discovery Bay CA
I am hearing you can use 2 stroke oil in diesel fuel to get better lubrication? Does anyone know the mix ratio to a full tank, and which or does it matter what brand is better? Thank you
brand is of no consequence, but you do need to use the ashless TC-W3
one quart to a full tank is the accepted ratio
toobsluver
Jackson, NJ
Theres a good thread on here somewhere regarding 2 stoke oil in diesel fuel... I'll see if I can find it. It was a good read, went over ratios, types, results, and a few links to a few sites.
:dunno If anyone decides to use it/try it ? For ease of purchase (?), Wal-Mart sells a 2 cycle oil under their "Super Tech" brand name (dark blue jugs). Only thing is though.. be sure and get the jugs that say: TCW-3, on the label.. it's ashless..NOT the [General Purpose], 2cycle oil.
Like TG sez.. 1 quart to a tank full, is acceptable (1oz per gallon of diesel). I fill up @ a halfa tank.. so I buy the 16 oz jugs.. cuz they're easier to store, in my bed box. Smaller'n easier to dump in too.
I've been using it for 'bout 75K now.. Won't & Don't.. run my 7.3 without it.
JimmyDee
God Bless America
Western Michigan
I've been using it for about 4 or more years now at an oz per gal ratio. Not sure how much it helps but from everything that has been said, it is a necessity with the new low sulfur fuel. For what the parts cost that the oil lubricates, it is a good investment.
Jim
Badassfx4
hamden/ct/usa
Is this just limited to the 7.3 or should I be doing this with my 6.4. I am running power services diesel kleen with every fill up.
Jim
Sez it all, right there i think.
Just an .02 ? The 7.3 (older engine) fuel systems were R&D'd to run on strait #2 diesel fuel. It had the [lubrication] qualities that all the component parts needed.. to give (injectors), a long(er) service life.
Then came LSC #2 diesel. Not so good for the 7.3.. but OK for the 6.0.
Then.. ULSC #2 diesel. Abit worse for the 7.3, OK for the 6.0... and by then, the 6.O had some re-designed.. component parts that operate well with the ULSC. The 6.4 was designed to run on ULSC.
NONE OF THIS means any...of our engines will Exsplode... if we don't use some sort of an additive. It's just that it's, "Out There".. why not use something to put a little Lube.. back in systems that were R&D'd for it. JMO.
Which one ? A Personal choice.
:dunno
Brad1103
