skertin3rd
I am hearing you can use 2 stroke oil in diesel fuel to get better lubrication? Does anyone know the mix ratio to a full tank, and which or does it matter what brand is better? Thank you
brand is of no consequence, but you do need to use the ashless TC-W3
one quart to a full tank is the accepted ratio
Theres a good thread on here somewhere regarding 2 stoke oil in diesel fuel... I'll see if I can find it. It was a good read, went over ratios, types, results, and a few links to a few sites.
I've been using it for about 4 or more years now at an oz per gal ratio. Not sure how much it helps but from everything that has been said, it is a necessity with the new low sulfur fuel. For what the parts cost that the oil lubricates, it is a good investment.
Jim
Is this just limited to the 7.3 or should I be doing this with my 6.4. I am running power services diesel kleen with every fill up.
