12v outlet install in pick-up bed.
A 40 amp would work.. on the 01 gauge, but for the "Bama Power Point" ?.. it All depends on what you plan to power up from it :dunno
Maybe you could Step Down, to 10 gauge, from the 01 gauge to power the new 12v plug-in ? That would give you a good range of accessory possiblilities.. or am I confused ?
I don't think you're confused. What you said makes good sense, I think.
Yer call Bama but 70 amps is alot. Bt that, I mean.. You could Smoke 12v accessorys if you ever wanted to power up more than one.. at the same time.. unless they were individuly, fuse protected. A 40 amp breaker would be my choice. Maybe you could start with a 40, then bump up when you find out what all yer guna use the power point for ??
platinum01
Willis, TX
It is the little things that make the truck. Bama that is a good lookin cover up.
I would get the $2.06 breaker. It is rated at over 3 times voltage and is weatherproof. Looks like a good deal to me, Bama!!
Dave :thumbs
I do see what you are saying Joe. I just happened to have the extra 70.
I found this 40 amp breaker for 2.06 and this one for 39.99 (scroll down)
Why such a diff. in the 2 prices? Aren't they the same? They look it.
Who knows why the price diff Bama :dunno
Kinda like the diff between the Marinco plug.. and the one you bought. Or a pair of Air Jordans verses a good pair of Sneakers from Wally World :lmao
I go with Dave on the $2.06 one too.
