madkaw
My 03' 6.0 is going in for the 06E17 update tonight. Should I be concerned? Seems as though these updates tend to get a lot of bad press. Anyone had this done with positive results?
Thanks
Thanks
madkaw said:So far its been good. I currently don't have any performance mods (67k). I haven't had a chance to check mileage, will keep everyone posted. Performance seems to have an overall increase. Boost pressure is toping out at about 26 psi. Mechanic said they were having alot of EGR's blowing out at 30, which I believe was changed in a re-flash last year. If you are running an aftermarket tuner, settle for good enough. The re-flash wouldn't be woth the hassle if you don't have a problem.
Mechanic also said he has seen 4 6.0's with Banks 6-gun system in the last month with MELTED heads and head gasket failures. Something with coolant around EGR being super heated before its dumped back to aluminum heads. Beware!
