theres a TSB on it...but its a warning to mechanics...doesnt say
theirs a resolution...the overhead display USED to be programable...
then they took that away in 03 or 04 and made it a dealer service item
that only they could perform w/ their FORD tool
id talk to your dealer, see if they can reprogram the overhead to
a larger capacity tank...heres the TSB info.
Check Engine Light on with P0460 Fuel Level Sensor Code:
This may be caused by a miscommunication of fuel level ststus between the instrument cluster and engine computer. This code is set when the engine computer does not see the fuel level dropping it expects. It may be caused by customer-installed items, such as a remote start system that does not power the dash when activated, an over-sized fuel tank or in-bed fuel tank. If these conditions do not exsist, the engine computer should be reprogrammed using WDS/IDS version 43.4 or higher. This condition can also be caused by fueling with the engine running, parking on an angle, or driving up a long grade. In some cases the fuel level sender may be faulty, or have a sulfur build up on the sender and have code P463(use Chevron Techron Plus Concentrate to correct). TSB 06-13-11
