'04 will not start
mantis
NY
The Batts should show 13+ static, 14+ running. How old are they ??
I'd get them [EACH] Load tested.
I wouldn't be thinking HPOP.. just yet.
I don't know how old they are.I bought the truck a year ago in August.They are CAT batts.Could this be the problem even tho in cranks fine?
YES!!! Batteries are the NUMBER ONE problem when the weather gets cold. It does not matter whose batteries they are. Get them load tested and have EACH one tested separately. If one is going south, replace them BOTH. What you have here is one battery in two places.
Dave :)
Dave :)[/QUOT
What Dave said, X2.
Yes. It may crank fine.. but cranking can reduce the Volts & Amps needed to actually Fire up. (PCM related stuff).
mantis
NY
Dave :)[/QUOT
What Dave said, X2.
I am going to get them tested tomorrow.Would bad Batteries cause it to run poorly? Like skip
Be sure they disconnect'm so they are EACH.. "Stand Alone".. when they test'm ?
Hard to say. Just an opinion but, Marginal-Weak volts/amps can cause All Kinds of Gremlins theze dayz.. now that everything is Computer Controlled.
mantis
NY
I will have to take them out anyway,because it would be easier then pushing the truck:D
mantis
NY
well this sucks! My '04 has an '03 engine in it.I went to check the ICP but it isn't located on the valve cover.I was going to disconnect that to see if I have a faulty sensor. I crawled under the truck and there seems to be alot of oil leaking someplace.The Batteries seem to be holding fine.Any other suggestions.The fuel bowl is full.Filters are only a few months old.
Is there anyway to check the glow plugs without a tester?
Yes, use an ohm meter on each one. Should be around 1 ohm if it is good. Open or greater than 2 ohm if it is bad
