00 7.3 throttle
I found the problem it was the uvch on the drivers side
;tu;tu WOW.. glad you found it !! It's always a process of elimination.. glad you nailed it early.
but I will look up those mods always looking for something better.
Those (and other fuel related) Mods will make yer 7.3 run, and sound... soooo much better.
On another note it's almost done with the transformation
We're look'n forward to seeing the Finished Product Jdark6
Jdark6
Gilmer Texas
Under valve cover harness I tried to post some pics tonight but I can't get them to upload
Jdark6
Gilmer Texas
That is today i will post a before pic when I get to my computer
01yellerCobra
Cali
Reading this thread has made me realize I have a whole new vocabulary I need to learn.
Jdark6
Gilmer Texas
Tps-throttle position sensor, cps-camshaft position, icp-injector control pressure, uvch-under valve cover harness, idm-injector driver module I hope that helps
01yellerCobra
Cali
Is the under valve cover harness for the injectors or are there a bunch of sensors in there?
