As you may have figured out... from reading on here... Two GOOD, load tested Batteries, with real clean (and maintained) connections.. juiced by an Alternator putting out 14.5 volts, @ idle... is absolutely required for these PSD's to start & run right. The ECM/PCM is Anal to Volts & Amps.
Many, many gremlins, thru the years, such as yours... have been fixed.. with 2 new batteries. It's also been proven that a 160, or [180] Amp Alternator is much better.. long term.. than the stock 120 Amp'r ?
Not Preach'n.. Jus' Say'n.
