Help Needed Swapping a 300 "I" 6 for a 95' 7.3
Advanced Adapters. They have a lot of tranny adapters for many engines. Why the disregard for the ZF tranny? There are auto trannys that will bolt up.
Dave :dunno
Diesel1050
Minot Maine
I want to stay with a standard. Is there some adapter to connect the current 5 speed (Has bellhousing as part of the tranny) to the 7.3?
Sent from my SCH-R970 using Tapatalk
Diesel1050
Minot Maine
Oh and the lift i'm fabbing for it will use 1 ton leaf springs with custom mounts. Pretty much boxing in the ENTIRE frame with 3/8 steel.
BamKat
TX
This sounds like fun!
Sent from my iPad using Tapatalk
Diesel1050
Minot Maine
Oh haha... thought you were being sarcastic! If you had said "That's a sweet Duramax" I would have hoped (Known!) You were being sarcastic!
The ZF-5 or ZF-6 has the bell housing as part of the tranny. Either transmission I think will suit your needs. A 4 speed will not be strong enough to handle the torque of the diesel. Look around for one of your friends who has one.
Dave :thumbs
79jasper
El Paso, TX
Any diesel zf5 from 88 to about 97 will work. Has to be from a diesel though.
Iirc, to run the zf6, you have to have the adapter plate from the newer engines.
Sent from my *******-SM-G890A using Tapatalk
