Help Needed Swapping a 300 "I" 6 for a 95' 7.3
Diesel1050
Minot Maine
I want to swap the 300 straight six gasser in my 89' F-250 for a 7.3. Found one out of a 95' F-350, and want to know if the current trans will bolt up? Its a 4 speed with overdrive. Thanks!
Sent from my SCH-R970 using Tapatalk
You will need a bell housing that bolts up to the 7.3. I am not sure the tranny will handle the torque. Get the 5 or 6 speed that goes with the 7.3 :welcome to SDD!
Diesel1050
Minot Maine
Well that's half the question! We're getting some where! Glad to know the 89' has a tranny with a removeable bellhousing. If it helps, the F-250 has a manual trans, with 1st,2nd,3rd,4th, and "D" (Overdrive)? And the transfer case shifter lever is on the floor to the left of the tranny shifter. It should be a Borg-Warner T-18 right?
79jasper
El Paso, TX
Well, I don't know about the gassers, but the diesels had the zf. Which has a non removable bell. I know it was offered on gassers also, so may want to check.
Sent from my *******-SM-G890A using Tapatalk
It has been a while since I owned my 7.3. Yes it had a ZF and it was one piece housing. Sorry I didn't remember that. Diesel engines usually have SAE numbered housings (1 or 2).
And FWIW ? I'd be sure there's enough suspension and frame work under the 89 to support and.... take the weight of a 7.3.
Purdy good model year verses engineering spread there ?
Diesel1050
Minot Maine
What tbe heck is "FWIW"? Definitely should be enough frame work, it's going to be lifted about 12", and I have some frame reinforcements planned.
Diesel1050
Minot Maine
So is the ZF the same bolt pattern for gassers AND diesels?
79jasper
El Paso, TX
"For what it's worth"
And no, the zf has 3 bolt patterns. Small block, big block, and diesel.
Diesel1050
Minot Maine
So this mist have a ZF. The case is 1 piece. Now the question, do I have to find a different tranny to mate to the 7.3?
