Xmas Lights on PSD
whatabudro
Launched
You should be able to see what the lights draw on the package before you buy them.
P= power/watts
I= amps
E= volts
E= volts
I= amps
R= resistance
P= IxE
E= IxR
You should be able to figure out whatever you need with that.
:Budro
P= power/watts
I= amps
E= volts
E= volts
I= amps
R= resistance
P= IxE
E= IxR
:Budro
thanks budro and the gang, it should be pretty straight forward.
here are the 2 types of lights i am thinkin about using
either the "rope" type lights, or the LED lights.
i think the rope lights would be easier to put on the truck.
the bad part is how to attach them to the truck, tape i guess
Tbar
SDD STAFF/Moderator
Little suction cups and zip ties.............
Tbar
bama-six-gun said:
remember, dont block the air flow to the zoodad bill :thumbs :D :roflmao
Actually I close off the from of the zoodad for the winter so the filter draws in preheated air to aid with engine warmup.:sweet
The front of the new bumper is a good 10" from the grille so there's plenty o air getting in.
We did get the tree up,lit and decorated Friday tho.
i just looked at the rope light stuff...put some on a shelf in my garage...
behind some motorcycle models that are "on display"...
the bulbs draw .05watts PER bulb...one bulb per inch...a 6 foot
section draws all of 3.6 watts (120v AC)...the 6foots white rope
light i bought was less than 6 dollars
lowes had 18 foot strands in red, white OR blue...for about
8bucks if you do the math (18ft x 12bulbs-per-foot = 216bulbs....
216bulbs x .05watts per bulb = 10.8 watts)
if your gonna put a wreath on the front make SURE it doesnt have
any RED lights on the wreath
