XM radio
TexasExcursion
GOD Bless America!
West Point, NY
CHPMustang said:
I initially installed the magnetic antenna behind the center roof clearance light similar to the way you're intending but it was taking a beating from the drive thru car wash so I relocated it just in front of the third brake lamp so I can pull it down when getting the Excursion washed :sweet
I've got mine mounted in the same spot as Bill; it's out of the way and really can't be seen (well, on a black truck, that is). You may need an extension to run the antenna that far from the unit, though.
W4RLR
High Tech Hillbilly
Sewanee, TN
powerboatr said:
thanks all
got a few cables to order when rray gets the final story going
its been 24 hrs ....tick tock :roflmao
Robert and all, I'm still working on it, having some problems with my digital camera, but this should get you started on the power supply wiring and feeding the wires for the adapter. The site will change dynamically as I make changes, so check back often.
http://members.cox.net/richardray/satradioinstall.html
This site will help out all of you Excursion owners as well, the wiring is the same.
Hope this helps...
Wood County Tx
ray
thanks
me being a dumb redneck :hail could understand teh instructions so far
dash just POPPS off, scary
bill
CARWASH????
