WOOT! Lift, wheels and tires on the way!
MONSTERPLOW
Cloud Booster 500HP
I 95n.b. 1/10 Keystone State
Its a beaut.:clap:. always have your eyes on the rear wheels of the vehicle in front of you , its a great gauge I use all the time.
If stopped behind any car or truck , you'll be able to go around it with ease.
06silvercrew
Morganton, NC
Well the truck is sitting level now, with a full 8'' of lift. I bought a rough country 2'' leveling kit for the front, (intended for a stock truck) so with those in the front, and the 350 blocks in the rear, ive got plenty of lift. Only thing I had to do wwas drill a new hole in my upper spring tower to drop the brake line drop bracket even further. I will add longer braided lines as soon as I locate some. Surprisingly the truck has very little to no bump steer using the stock track bar with only the drop bracked designed for the 6'' kit. No more tire rubbing either. Ill try to post some new pics when I get time.
Scott
