Will the torqshift go to a 6 speed?
Rcannon
HOWDY!
USA
JIM_C said:
I'll see if I can dig it up in the archives over there.
good luck with that. From the feedback of late, searching the archives is a crapshoot at best...
ISurvivedNMU
Member
Michigan
Would it be OK if you copied it over here... or PMed me with it....
Some of us no longer have access "over there"
JIM_C
Turbo Lover
Tucker, GA
PM sent. For others' reference, the Torqshift tranny gear ratios (according to the person who developed the SCMT programmer) are:
"Here are the ratios:
1st: 4.219:1
2nd: 2.531:1
3rd: 1.656:1
4th: 1.219:1
5th: 1:1
6th: 0.7:1
The shift schedule when accelerating is 1,2,3,5,6
4th gear is not used on upshifts.
There are also some situations that dictate a skip of other gears.
(A 1-3 shift occurrs often in low load, low throttle situations)
The DOWNshift schedule is 6,4,3,2,1 (it will skip gears other than 5 depending on the situation).
Notice 5th is a 1:1 ratio, but 4th is a 1.219:1 ratio....
4th Gear allows for engine braking on decel and this is why it is used for decel only instead of 5th gear.
So when you make a WOT run and you think your truck is shifting 1,2,3,4,5...it is, but it's actually 1,2,3,5,6"
Ricksofla
