Wingdog
any year powerstroke will fit.just have to change certain parts.
comeing from a bus you will need to swap the oil pan,flywheel,trans adapter,exhaust manifolds/uppipes,possibly the oil cooler,HPOP reservoir,water pump unless you read the directions on converting your truck to run the IH pump with the coolant filter,bottom pully and all accessories and brackets.possibly the turbo or the compressor housing and intake Y pipe.and some sensors here and there as well as the passengers side valve cover.
Basically if you need to change all of the above then your still good. All you need to do is clean off all those parts off your motor and swap them over. Basically at least the block will work for you.
