Widest dually tire -no spacer
Deadman514
Hamden, CT
It's me again. Going to cut my fenders and put a bit of lift. Wondering what the widest tire you can mount on stock wheels with no spacer in the rear of the dually.:thanks
ranger boy
Banned User
probably not much, when i had my dad's dually there was like a cm of space between them
Deadman514
Hamden, CT
Ordered spacers from ORU. The 10.5s belly out too much. Goin 12.5 all around now!!
ranger boy
Banned User
there ya go, your best bet is spacers, there's no room in there without them
Crazyhorse
Suisun, CA, USA
who makes a spacer that is hub centric, and locates the wheel hub centrically? A spacer that doesn't do this is BAD NEWS, and will cause problems (potentially even leading to wheel failure)
Deadman514
Hamden, CT
Actually the ORU spacer IS hub centric. You must remove the axle shaft in order to install them (which sucks if you have to change an inside tire).
FlorWhitfe
