Who's smarter than me? with electrical???
Mike.Honcho
Shake N Bake
Paradise
I'm thinking that your genset is getting worn out and not loading correctly, you should have absoloutely no problem starting a 1hp motor on a single 110 outlet, a true 1hp motor will run about 16 amps.
Double check all connections and ensure that the contacts in your pressure switch are good.
See what the local shop will charge you to have your genset load tested.
Correction
1HP = 746 Watts
746 Watts / 120 Volts = 6.21 Amps
Brad1103
