White smoke under load
sagebel
Stock? Pfft!
Albuquerque, NM
Well, maybe..
White smoke is moisture, so that would be my first thought.
Now, I can see some as condensation burns out of the exhaust (would account for your muffler "leak"), but I can't see it after the truck has been run for a while, and surely not just under load.
Where does your CCV vent to?
I have about 200 miles since the injectors were re-installed. My first couple trip to and from work after the install there was a lot of white smoke. Much less yesterday. I'll keep watching the side mirror to see if I see any difference today.
CCV vents to atmosphere.
OK.
I'll check back in this evening when I get home
sagebel
Stock? Pfft!
Albuquerque, NM
Just did a compression test. Everything is between 390 and 420. Found oil residue inside the I/C boots. I have had the CCV re-routed for 4 years so I doubt it is residual. Now to figure out what I am going to do for a turbo.
Tail_Gunner
CRJ & ERJ A&P Mech.
Da U.P.
Bean's has rebuild kits where you can replace your own turbo bearings and seals.
Call Bill at powerstroke help.com. You need to tell him whats going on, he's in Buford, GA
Tail_Gunner
CRJ & ERJ A&P Mech.
Da U.P.
I don't think you can rebuild a 38r.
I rebuilt the turbo on my early 99 before I put the Dominator 66 in. Took more time to pull & re-install than to do the rebuild itself.
Give Bean's a call. Worst he can say is you're right, can't be done. But again he might tell you it's do-able for a lot less than a new turbo.
sagebel
Stock? Pfft!
Albuquerque, NM
Called Bean. It maaaayyyy be rebuldable... by a turbo shop. The ball bearing turbos are not so shade tree friendly. I'll probably end up calling Dieselsite tomorrow.
