JRJ04
1. Not knowing what "a little over full is".. Drain 1 Quart out and drive it for a day or two.. check for the sounding funny/not running as smooth thing. What little oil remains in the HPOP is moot...IMO.
2. Check yer PS pump fluid level. Add ATF (yes, ATF) as required ?
ok good...im glad theres not a lot left in the hpop.
sure enough the ps fluid resivoir was low! i added some atf to it (i think too much cause it puked a little) and the sound is still there to a degree, but it seems like that helped a bit. Should I flush the whole system? I know theres instructions on here somewhere on how to do it.
Something else I thought of about the running/power issue. They reflashed my computer when they did all this. I wonder if that could have anything to do with it. Maybe there was an updated flash out there that wasnt as good as what I had on there. I know there were several reflashes for the 6.0's but not sure about the 7.3's.
