Which Tire?
bspan27801
I love those FORD's
Newark, Delaware
Load range E = 10 plys
Load range D = 8 plys
Load range C = 6 plys
etc, etc
Hope this helps
I would recommend Load Rang E for superdutys because of the weight you might carry Nothing lower than 8 plys. If your one that never tows anything heavy or carry anything in your truck bed you'll probably be fine. The thinner sidewalls do give a softer ride, but the weight on them when towing or carrying heavy loads generates a lot of heat and could cause a blow out!!! yikes. Just my 2 cents .... Good luck
Jesse East
King George Virginia
Partick,
How will you make tires that large work on the dual axel? You will need new wheels, but even so, you may need a spacer between the wheels----and they will stick way out from under the fenders.
Just wondering----Jesse East
DragonSlayer
Pensacola FL
Had good luck with Toyo's, I would also recommend load range "E" only. The trucks are too heavy for the "D" range tires....just my opinion........:)
Ricksofla
