Which 2" lift for a '00 F-250
BIG DUTY
F-250 Care Taker
Traverse City, MI
After installing the Summit 2.5" leveling kit, the front became noticably higher than the rear. I then added Superlift rear add a leaves. This leveled my truck perfectly and gave it taller stance at least 3" in the front and about 1.5 in the rear. They have been installed since febuary and show no sag since installed. I did develop a vibration at 10-20 MPH. Anyone have any solutions. I removed the drive shaft and the joints seem to be fine.
keanoknick
Big Stroker
Cowtown TEXAS
You could try to shim the carrier bearing, that's what they do on lifted trucks, I think mine is shimmed about 1.5 inches.
atk
Moderator
simcoe, ontario, canada
ditto on shimming the carrier bearing...probaly anywhere from 1/4 inch to 1/2 inch should do the trick...hope this helps
BIG DUTY
F-250 Care Taker
Traverse City, MI
Im not sure what you mean by carrier bearing. I do not have a carrier in my drive shart. It has a u joint at top and bottom with a double u joint in the center.
atk
Moderator
is it a one piece or two piece driveshaft?....sounds like you have a 2piece shaft and if you do should be located close to where your double u-joint is(CV joint). it will be bolted to the crossmember and will support the driveshaft...if you don`t have this, then you have a one piece driveshaft and you will have to shim the rear differential with shims(they go where the factory lift blocks are), to get the proper u-joint angle back....hope this helps
BIG DUTY
F-250 Care Taker
Traverse City, MI
I have a one piece drive shaft without a carrier. I understand the concept of shimming the rear diff. I have done it on my jeeps multiple times. I just figured that with only a 2" increase in the rear suspension it would not be a problem. Being a long wheel base truck, a lift of this size does not usually cause a vibration.
keanoknick
Big Stroker
Cowtown TEXAS
WOW!!
You are the first person I've met with a one piece driveshaft, that didn't have it custom made, consider yourself lucky IMO
Brad1103
