where to stuff huge power inverter?????
Fine69
Cranberry Twp,PA
1050 Watts is only good for 8.75 Amps, Watts/Volts=Amps, 1050/120-8.75. So I wouldn't go too crazy adding Receptacles all over your truck. I'd stick with just 1 centrally located.
94f450sd
certified nutjob
plymouth,ma
under rear seat, raise it a Lil with brackets, and a heat shield about should do the trick, mine is the right now but coming out due to stereo amps going there
my amp for the 2 subs wont even fit under my rearseat.and that is much smaller than the inverter i got.
94f450sd
certified nutjob
plymouth,ma
i was thinkin for laptop chargers and stuff like that.although a refridgerator would be nice.keep that mountain dew at the perfect temp 24/7 :D
94f450sd
certified nutjob
plymouth,ma
11.57”W x 5.94”H x 11.04”D
i was thinkin last night(ya thats where the smaoke you guys saw was coming from)i want to get rid of the batteries under the hood and mount a battery holder under the bed with 4 REAL truck batteries.then stick the inverter where one of the batteries were.
