Where to buy ring-and-pinion?
rammertide07
Rogersvilles, AL
Where is the best place to get a rear-end ring-and-pinion set for my truck? I have an axle seal leak, which I will fix probably when I can buy the ring-and-pinion, and it has caused the gear oil to leak out and cause some wear. Not too major....YET. I'm not sure what my ratio is but I think its about a 4:10, and I know I have to buy what was in it to begin with to match my front end. I have seen regular gears and then I have seen THICK. gears....which should I get. I dont use 4x4 that often, only when I need it. Thanks
rammertide07
Rogersvilles, AL
And would my truck have the 10.25"? I think thats what it is but I'm not too sure what that actually is asking about. Is this something I can do at home by myself or with help? I'm a sewing machine mechanic so I'm use to taking something apart and putting back together. Any links to sites showing how to do it would be great. Thanks guys.
dpantazis
#12
under the cheddar curtain
you should have stamped metal tags at like 10 o'clock and 2 o'clock secured by the cover bolts. they will give you the info you need to ID the axle and ratios.
rammertide07
Rogersvilles, AL
Thanks. I found the seal and its about $40. Is that all I need to buy to redo the seal?...as far as keeping the fluids in. I know I'm going to have to buy more gear oil. If that is all I need to buy then I'll go ahead and fix that to prevent any further damage and just prey that the gears hold up for a while. They are still in pretty good condition. You can notice a little wear on them. I have a kid on the way and I'm trying to save all that I can.
FlorWhitfe
