Where do you connect the fuel pressure guage
jeffnzoya
Butler, Tn
I wan't to install a fuel pressure gauge in my truck. Could someone tell me where (looking down on the fuel filter canister) you hook up the line.
Jeff.
Jeff.
Check yer " Get Ugly" Post Jeff
jeffnzoya
Butler, Tn
Thankx. I found it. Haveing a hard time finding a gauge locally. I found an auto meter and was going to get a three hole pod but it say's not for use inside the vehicle.
I wonder if this is this a disclamer that they all have?
Jeff
Jeff
You can install an Isolator (what I did). You run a fuel line to it under the hood, then a line filled with Coolant.. to the in-cab gauge.
That way, should the gauge or line fail.. you won't have Diesel fuel all over, in the cab. (what the disclaimer's all about)
One source would be [www.dieselpowerproducts.com]
jeffnzoya
Butler, Tn
I think I will just mount it under the hood.
Going to start another post about air intake. Check it out if you don't care.
Jeff
Brad1103
