Okay so i go to change my alternator, and i am told there are two alternators, i can only see oneso i take it off and have it checked and it says its okay, so i put it back on and the idiot light went out and i guess i dont need an alternator, while i am in there i figure i will change the belt, mind you i had released the belt by taking the alternator bolts out, and that is not going to work to put the belt back on so i really start looking at it and i cant beleive the fan shroud design, do you have to remove the fan shroud to put a new belt on??
If this is the way it is??? has anybody seen any MODIFICATION to the shroud that makes it a little easier to get to the tensioner, i can barely get two fingers in there!!!
I was going to take it off but even that looks complicated, anybody who has any experience dealing with the 6.0 fan shroud i sure would appreciate any tips or shortcuts to working ont the belt .
