whats this plug, i have one on ea fender well
bears4x4
grease monkey
katy texas
sure looks like what i unplugged to pull out my hubs weeks ago....
it is up behind the plastic wheel well insert?!?!?right
have you owned truck since new?? previous owner perhaps unplugged??
as it warms up today i could go out and snap some shots for reference, unless someone beats me to it...........:sweet
thanks, i bought it used, never noticed anything unpluged at the frt hubs when doing brake jobs, but a refference pic would be awsome:hail can wait to solve this mistery
bears4x4
grease monkey
katy texas
well while under my truck today i looked again, theres no plugs anywhere on the front suspension or brake that are missing anything, to check if they are running light plugs, when would they be powered up, with lights on right?
no-red 6 0
Senioritis
southmetro MN
this is the passenger side abs plug-in...it goes to the hub...........
it is NO light hook up...
i just realized that i should go take a pix of it 'at' the hub so you can see where it 'might' be plugged into on yours..give me a bit...:innocent
here you are. you can see from the fourth pix where it would be bolted to the knuckle and where it would bend down into the hub.
the last pix is of the old one and how it looks...
hope this helps...not sure why yours is missing your abs line...:eek::sorry as long as your truck was capable it should have one...:doh:
good luck w/ investigating...
georgetown texas
Its abs sensors. Look at the hub that i gave you there is a hole with a threaded hole next to it that is where the abs sensor goes. On the top. Damn i'm good had a pic of both on my phone.
no-red 6 0
Senioritis
southmetro MN
not sure if good is the right word for you....:lmao
i had to re-edit my post or i'd have beaten you to it...:innocent
georgetown texas
Hey crackhead if ya have abs with auto hubs you'll 2 count em 3 lines going to behind yer wheel. One vacuum line, one brake fluis line, and the abs sensor. Whip out that crappy blackberry and take a pic behind the wheel.
no-red 6 0
Senioritis
southmetro MN
oh, so now i am a crackhead because i forgot to take a picture of my shiney d/s rotors new......maybe forgetful but not a crackhead... and i don't own a blackberry...not rich like you...:tounge
i did not purposely take a pic of the 3 lines cuz he was only needing the abs line...:D
sorry for going off topic, back to original programming
:stir
bears4x4
grease monkey
katy texas
plug questions
thanks for the pics Red and Rooster, i have manual warn hubs, i looked and saw no holes like you showed rooster and no other lines like in the pics red other than my brake like, ill clean up my hubs tomorrow and keep looking, it would be weird to have the plug but no abs sensor in the front unless the former owners changed out the front end like that????? at least i have reference pics to go by, thanks guys :sweet
