What to clean ATV with?
willtill
Hanover (hangover), Maryland
95_stroker said:
Elk blood.
Once that stuff cooks to the exhaust you'll play hell getting it off.......
......are usually still dripping down through that back rack right onto the muffler.
My plan is to put the deer across the front rack. Granted, an elk is much bigger and you would have to utilize both front and rear racks.
I don't want that blood dripping in between the seat and the battery/airbox compartment ....as well as the exhaust, now that you've mentioned it.
Kindest Regards,
-Will in Maryland
Be careful with a pressure washer. Water can get blown into places it doesn't belong very easy. I would guess that your owners manual tells you that too. Simple green, garden hose, toilet brush and elbow grease is the best way. You can get soft bristle brushes in all sizes and shapes to get into those hard to reach spots..
willtill
Don't plan to use my pressure washer on the Big Bear. Water hose has enough pressure behind it. Will try some of the chemicals suggested here with the hose.
Kindest Regards,
-Will in Maryland
Brad1103
