what size tires
jto89
Eastern mass
I have a stock suspension on my 2003 f350. my question is what is the biggest size tire you can get under it. i have a plow in the truck so im kinda consurned about the front end drop when the plow is on. i plan on keeping my stock rims for now and in the future if i get diffrent rims i will keep the stock ones for plowing and winter use. also what do you guys suggest for a good all terrain tire. like i said i plow in the winter and need a good tire. all input will be greatlly appreciated. Jack
35's will work but you'll need a 1" spacer for the front bumper to clear turns and some miner metal work under the fender well at the cab to.
Mac Land
Pasadena /CA
Same type of question. I have a 2008 F250 4x2 It has the 18" stock rims, I'm do for new tires soon and I would like to get the largest and most aggressive (wile still quite on the Hiway) that I can fit. Does anyone know the limitations of what I can fit?
I think the 285's work out to about 33" tires. The LT265/75R 16 E are about 31" tall.
