The ports inside where the actuator goes, I drilled them out slightly and drove in a BB. (Iirc)
I don't remember doing anything with the hole the "sensor" (which is actually more like the ipr by function) is in. Can't remember why I didn't. I know I left the stem and Solenoid. I just cut the wires off.
Where the actuator rod comes through I put a pipe plug.
On the valve it self I removed it completely and used pipe plugs, as I'd heard of issues using freeze plugs.
Of course mine is slightly different being a obs, but it's the same principle.
You could just leave everything in place, and unplug it until you can just buy the delete pedestal.
