snyder5630
I have a 2006 6.0 with Edge Juice with Attitude, Airaid cold air box and Bully dog exhaust. At what EGT temp should I worry about it being to hot? It currently runs between 600-800
X2 ! The TEST that was mentioned is flawed. What if you read 1250 on that hot day, then add 150. 1400deg.'s is NOT a good thing. My opinion is if you see 1300 or even 1350 for a second or few, it's not fatal; just lighten up the right foot a smidge.Is your pyro probe pre or post turbo? Pre turbo temps should not exceed 1250 degrees and post you should subtract about 300 or so off that.
