dmcvey_1999
So this weekend I took the superduty out for some wheeling fun. I was towing my 1987 bronco with a 8 x 20 flat deck trailer. The truck was pulling fine, EGT's went no higher than 980 degrees, transmission temperature at 170, engine oil temperature 204. I pulled into my buddies yard and parked. He asked me to move the truck, started the truck back up and put it in gear. When I hit the accelerator, no boost at all!! Truck had no power at all. Tried in reverse, 4 hi/4lo symptoms all the same, no boost and black smoke out the tail pipe. Pulled the diagnostic codes and codes indicated 06011 FICM, and EGR circuit malfunction. I figured the EGR was acting up so I pulled the plug on the EGR valve. Okay now truck has no boost and white smoke coming out the tail pipe. Let the truck cool down for about two hours and tried again. With EGR valve disconnected still white smoke and no boost present. I called my buddy and put the 250 on the trailer and back to his house. We let the truck cool for another couple hours, truck started right up boost and all. We pulled the EGR valve, it was not dirty, had just been cleaned less than 2,000 miles ago. Cleaned it anyway. I checked my battery voltages and they are indicating 10 volts. Will this cause all these problems? Sorry about the long post, just trying to provide as much information as possible.
