hntnv
Nevada
Got the SD all washed and waxed for the memorial weekend camping trip.
sagebel
Stock? Pfft!
Albuquerque, NM
I'll bet you learned some tricks. Write a book, or create a DVD, and sell it to us.
Dave :)
It wasn't much different than Bama's install. Our tanks are in the same location (under rear passenger door. The reel I used is a little larger in diameter I think. I used a Kobalt reel that I had in the garage. I am working on a trick storage solution to keep crud out of the coupler. I'll try to get some pics next weekend. It's going to be a busy week.
Scott
Bolt
Plainview, Texas
I run a Mack truck off road, so it gets muddy all the time. What I did on the air system is run the male end of the coupler set under the truck, it's easy to clean, you can wipe the mud off it with your finger and crack the valve to blow the inside clean. Then plug in the female part of the coupler and I can air up the tires, etc. May or may not work in your application.
Today I abused my truck :doh: Used Crummy to teach my 17 year old son how to drive a stick...
He actually did very good but don't let him know I said that or he might think he can use Crummy all the time.
sagebel
Stock? Pfft!
Albuquerque, NM
Maybe its not so trick. I assume you are carrying a douple female adapter?
actually did it Sunday..
replaced the HPOP O-rings.. still has the oil leak.. looks like fittings next..
Jriltex
