sagebel
Stock? Pfft!
Albuquerque, NM
Installed sway bar end links with new bushings. What a PITA. I don't have a press so I had to get creative with a drill press, hole saw, hacksaw and cold chisel. Also ordered a new trans cooler (new 6.0), so much for saving for bigger oil this month. Since the truck is down I pulled the front bumper, wire brushed all of the rust on the frame and bumper, treated with rust neutralizer, and repainted. Re-routed the block heater cord to run inside the frame in preparation for the plug mod.
Tail_Gunner
CRJ & ERJ A&P Mech.
Da U.P.
I put a new 7-pin trailer cable connector on. The new one has a weather resistant cover on it to help prevent moisture from getting inside when no trailer is hooked up.
hheynow
Señor Aceite de Soja
Northern California
Today I'm spring cleaning the interior. The dog hair and debris will be vacuumed with my shop vac. A year's worth of road dust will be blown out with a leaf blower. Then a wipe down with Simple Green. Then Windex. Then I'll treat the A/C system with a deodorizer. But no matter how clean I get her she's still an old cow with 310K miles under her hoofs. :D
bears4x4
grease monkey
katy texas
:Dim installing a stereo, 2 12's plus a additional 4 highs in custom boxes:D now wheres the dang glue and velcro
Vacuumed the carpets and floor mats.
Washed, scrubbed the dirt off of the all-weather floor mats.
Wiped down the red dirt that my kiddies tracted in and somehow got on the door panels.
Re-carperted a cheap homemade center floor console that I made about 4 years ago.
bears4x4
grease monkey
katy texas
trying to fix the dang door open indicater switch, with wd 40 from what im told to do?????
Murf06PSD
Gulfport, MS
in stalled the upfitter switches i bought. Found a good write-up that even told exactly what size bolts to use to mount it(mine didn't come with it). Took about 45 min.
Washed it
Waxed it down with the new Lucas Slick Mist spray wax
Used Turtle Wax Tire foam spray on the tires
Wiped all the wheels down real good
Armor All'd all the exterior plastic areas & bed cover
Washed it
Windex'd all the chrome doo-dad's & thinga-mabobs
fixed it for you :tounge
I might wash mine today...
dpantazis
#12
under the cheddar curtain
put in a FM transceiver so i could listen to the ipod/sirius static free. replaced a bunch of blown fuses (WTF?)
i drove it, HARD. coughed soot in the face of some pimple faced teenager driving some hyndai with a fart can muffler.
Fed it a whole load of B11.
Pm_guru
