What about 5" exhaust?
JohnBoyToo
DFW, Tx
I need to offer a word of caution...
just hearsay from others (other than DALPilot would had to replace his tranny),
but enough to know it as an issue worth considering....
Many have stated tranny problems with the Edge - it just doesn't control the tranny as well as others - only by defueling at shift points....
it's your call, just offering some info up...
good luck !
draftlover
Crybaby
Wyoming, U.S.A.
good luck !
Thanks for the advice:thanks , but the deal is done:) . I just bought an Expandit 4" into 5" exhaust with all this:
Lower EGT's 300 Degrees
Add 25 Horsepower & 50 Ft Lbs Of Torque
This is a 5" Aluminized exhaust. Expandit system consists of 5" intermediate pipes, a high flow Expandits diesel muffler with a 5" tailpipe. With the direct fit turbo flange, full mandrel bent tubing, installation is a breeze. This system comes with all off your clamps and hangers that you will need for installation. Horsepower and torque gains along with better fuel economy can be noted as well as a drop in EGT. (Exhaust Gas Temperatures)
AirRaid Stage II intake including:
AIRAID intake kits provide increased airflow into the engine by removing the factory air intake box and replacing it with a high-flow conical air filter element mounted on the end of a smooth tube.
8-10 HP/10 ft lbs Torque Gains
Washable and Reusable Filter!
Allows More Air into Engine!
Increase HP & Torque
Easy to Mount Brackets!
Limited Lifetime Warranty!
An Edge Platinum W/ Attitude with all this:
• FEATURES FULL TRANSMISSION CONTROL
• Defuel During Shifts
• Defuel During Transmission Slip
• Defuel During TCC Lock-Up
• Adjust shift firmness and TC Lockup points
• INCLUDES TURBO TIMER!
Turbo timer feature prolongs turbo life by allowing the truck to continue running after shut-off until a
predetermined EGT or Time is reached.
• DISPLAYS AND CLEARS TROUBLE CODES
• Including complete text descriptions of the error code
• SHOWS TRUE SPEED
• By taking into account changes in tire size and axle ratio
• ADVANCE SAFETY FEATURES INCLUDE:
• Automatic defueling to prevent excessive EGT, turbo boost and transmission slip
• Cold engine protection
• User selectable audible alerts for EGT, speed, boost, engine and transmission temperature
• REPLACES GAUGES
The Attitude displays all the information a set of gauges would including RPM, Boost, EGT plus:
• Transmission Gear
• Transmission Fluid Temperature
• Transmission Slip Percentage
• 0-60 and Quarter Mile Times
• Backdown Percentage
• Intake Air Temperature
• Engine Oil Temperature
• Torque Converter Slip Percentage (when torque converter is locked)
• Engine Coolant Temperature
• Load Percentage
• Throttle Percentage
• Correct Speed MPH
• Torque Converter Locked
• Engine time On
• REMOVES SPEED LIMITER
• For race applications only
• DRAMATICALLY IMPROVES DRIVEABILITY, TOWING PERFORMANCE AND MILEAGE
• 5 ON-THE-FLY ADJUSTABLE POWER LEVELS
• EASY 30 MINUTE INSTALLATION
• UP TO AN ADDITIONAL 115 HORSEPOWER*
• INCREASE TORQUE UP TO 240 FT. LBS
* Power levels add 25, 40, 60, 80 and 100 horsepower. 115 horsepower gains available with Hot Juice upgrade and is for race applications only.
And a pillar mount for the attitude to make it look pretty.
I'm ready for it to be here...NOW! I guess it'll be a week or so before I see it. I hope I have time to put it all in/on!! I'll have a beast when I'm done!!! :thumbs
draftlover
Crybaby
Wyoming, U.S.A.
DID have some bank...now this :2c is all I have left! Got it all for $1545.00 including shipping:wow !! Got a rockin deal thanks to the good guys at ETR-Diesel Performance. :clap: :ZigBang: ;tu :) :thumbs
Heres their web address: Auto-Forward Page
They have a ton more stuff than what they have listed on the site. Call if you want something and they might have it. He beat prices to make the sale with me, too :thanks . The deal I got was almost scary:hail !!!
Jriltex
