Weak starting
I mean since then. The obvious things first, like the batteries. They should be load tested to see if they are good. A volt meter will NOT tell you if they have the capacity, only the volts. YOU have to do the work, we can't. :)
Dave :)
clintusaf
Clint
Bossier City
Ok, I crawled under the truck and found a broken starter housing bolt. They are the really long bolts that run parallel to the starter. I backed both housing bolts out to observe the inside of the starter and there was a lot of soot. I ran and got a new starter from O'rielly's Auto for $189 with a lifetime warranty. I looked at motorcraft starters and refuse to pay $450. Installed the new starter making sure to disconnect the batteries first. After installation, turns over perfect.
The new starter sounds alot different. My old starter was louder and had a kind of high pitch wine. This new one is much quieter with out the wine. Why would this be?
The new starter sounds alot different. My old starter was louder and [had a kind of high pitch wine.] This new one is much quieter with out the wine. Why would this be?
The OEM starter probably had a bushing/bearing going bad, causing the whine/squeal.. and also the soot (grindings) as it went south ?
FlorWhitfe
