water in diesel
R1junkie
edinburg, tx
got water in diesel engine shut off drained out most of the water from the tank what additive is good to breakdown the water....
I personally use Howes but there are many others on the market. Schaeffer, Power Service and many others also make products that will remove water.
Kleetus
Butler PA
I don't know that any of them will "remove" the water. It's still going to convert to steam in the injector which is the problem, along with possible hydraulic lock.
Unfortunately, you're best bet is going to be to drain that pia HFCM...
Fandini
Binford 6100 Owner
Burlington N.C.
I get the water in fuel light from time to time but draining the filter housing doesn't seem to help. I always have to have the housing taken apart and cleaned. It seems to have this substance that looks like partially dissolved dookie stuck inside the housing, is that bacteria or just trash and water?
Kleetus
Butler PA
I think there was a TSB on that problem.. I'm not sure if it was because of the heater or lack of, I've been lucky with mine so far...
Ricksofla
