yea im leaning towards the tires...but it was just a coincidence that this started right after i installed the the diy intake and did the foil delete.
The vibration is something like this...if you were to draw the wave length of the vibration....the waves are very small and strong (a small standard deviation) as opposed to huge waves (larger standard deviation). Make sense?
yeah, coincidence
short wavelength with high amplitude is usually something rotational under torque.. check your u-joints and center support bearing too
