Yooper75
Boost Junky
Ok I am really tired of the front end vibration I have in my truck. Here is a little back story on things, I had new tires put on it September and I also had new ball joints, passenger tie rod, passenger side hub, axle joints and rear U-joints done. I also changed the rear diff fluid and added new friction modifier just to eliminate that as a possible cause. Yesterday I locked the front hubs to see if it when away and it remained the same but I have a questions though. If I turn the hubs from auto to locked that should engage both hubs you should not be able to turn the front drive shaft at all right? I could move the front drive shaft going to the transfer case freely until I engaged the 4x4 via the dash switch and then everything locked up with no play. What else can I look at to eliminate possibilities? I am completely stumped on this one.
