Very rough idle help please!!!!!!!!!!
bigdiesel99
corinth texas
in my experience when the truck dies when it goes from "start" to "run" it has bee a IVS (idle validation switch) or TPS on Fords the IVS/TPS is onunit with the Throttle pedal... could be costly i will look up the values you should see on a meter and post them... hope this is not the problem...
hammer450r
NJ
Thanks but i dont think im showing those exact symptoms, The truck isnt really running while cranking its just stumbling
hammer450r
NJ
Where do i get them at the ford dealer or is that an aftermarket item? I need the truck on Sunday to go practice so i hope i can get what i need Saturday
It looks like i can get them at autozone. What about these clips for the harness? and should i get a new VC gasket or reuse?
roosterdiesel
Earl needs B100
Amarillo,TX
Wow! 7 out of 8 GPs bad.:eek: That would make it hard to start.
Not sure on the clips at Autozone.:dunno I believe there is an updated VC gasket that doesn't need the clips. You may try an International truck dealership, mine's open 7 days a week.
hammer450r
NJ
7 out of 8 are good arent they? I was thinking one was bad. Is 1.3 ohms bad?
Generally speaking, anything over 1 ohm is considered suspect as being bad. And of course 0 is bad as well. The higher the resistance on the GP the more amperage is consumed to heat the GP up. Ohms Law applies here.
hammer450r
NJ
Check you valve cover plugs and make sure one hasn't worked loose. If they are both on, unplug one and see if it kills the truck or has no effect.
HOOOOOORRRRRAAAAYYYYYYYYYYYYYY!!!!!!!!!!!!!!!
Clip fell off under VC. changed gasket and glow plugs anyway, runs like a champ
I owe all of you dearly. Thank you all soo very very much
hammer450r
NJ
Thanks big and the same to you. Be safe driving this weekend
