vacuum source on 7.3 for Hydrogen cell install
93turbo_animal
Marengo,ohio
you don't need anything the generator builds pressure as it works. Not a lot but enough to push the gas out thru a bubbler and to where you need it just hook you line anywhere between the filter and the turbo and it'll be fine
93turbo_animal
Marengo,ohio
any connection to the intake is going to be preasurerized when you make boost and even running empty at 55 I make about 5 psi so your almost never going to run on your hho
Pm_guru
